96xp 782 cranks doesn't start
Doing that now...any tips???
edit: Got all six bolts including the bigger one that mounts to the eninge, still won't pop off, does the oil pump one hold it on??? The top part prys off but the bottom seems stuck on
its a big magnet, its a pain in the A#!, so be careful make sure ALL the bolts are out, also you need to jack up the engine a little...
There's 3 bolts at the bottom of the cover that you are not going to be able to remove unless you raise the motor. Remove the two bolts that hold the front motor mount to the hull. Use a nylon strap under the mount and lift the motor with a come a long. Place a block of wood under the motor. Remove the come a long. Remove the three bottom bolts on the mag. cover. You can leave the oil pump alone.
Lou
