Seadoo Tuner
First start attempt for this year, has run fine the last 4 years except for the odd hot start issue a couple of times after running all day last year.
Plugs are wet so has fuel, has compression, has spark. Tried to start and turned over but wouldn't fire up. Switched to Reserve and fired up for a second, then no more after many multiple times trying on reserve and regular tank setting (choke on and off). Poured fuel in cyclinders and down carb throat and still not firing up.
Just cleaned and rebuilt the carb with genuine mikuni kit, pops off at 27psi every time, no leaks, carb is golden. Not sure what to look at next.
