Royaldata1
I have a problem I hope you can help, I have a 96 Speedster I bought 3 years ago. Didn't run great when I bought it but the price was right. I cleaned the carbs and it ran like a champ. Son had it on the lake earlier this summer and had power loss in port engine. Also an over heat warning tone. Claims to have shut it down quickly and limped back on one engine. I found upper exhaust pipe had come loose from exhaust manifold. Was concerned about the overheat condition and did compression test before reassembling the exhaust. Compression on one cylinder was 128 and the other was 130. Since I didn't have a manuel I compression tested the other engine and had the exact results one cylinder at 128 the other 130 so I figured the compression was good. Repaired exhaust with new gasket and rubber grommet assembly that was chewed up. Ran the engine with the hose attached and sounded good revved to 6K with no problem. Launched it tonight to try it out on the lake and the port engine has no power. Will not make more than 3K rpm at full throttle. Starboard engine seems fine. Just wondering if you have any input on where to go from here. I am two-cycle neophyte although I know a lot about 4 cycle and diesel. Just not sure what is the best direction to take. I am pretty sure I am working with the Rotex 717 engines.
