Ok I adjusted the idle screw and it idled low about 2k a couple of times hit the throttle and it would stumble... I got it adjusted to about 3k.. it fired up and I hit the throttle a couple times it seemed good... then I tried again and it started running away by itself after I let off the throttle, I hit the stop button, pulled the lanyard off and it didn’t stop until I choked it out... does the engine need to be warmed up before making adjustments? What are my next steps I feel I’m really close just don’t understand why it wants to run away... when the idle was lower and I would hit the throttle it would come back to low idle... this time it would come back for a second surge then run away... man I’m frustrated
