Ok I haven’t had a chance to adjust the cable yet.. I have been getting home too late from work.. but I took a look yesterday and the 10mm nut on the inside, (left, closest to the carb or under it) is almost at the end of the threads on the cable, the thumb throttle has basically no play.. when you touch it, it moves the cable... so I want to adjust it further out? I may have only a couple threads left until it’s all the way out correct? May only be a couple turns...
