PolarCelsius
Last time out on the water, when I would turn off the engine, intermittently upon putting the key back on the high temp LED would flash a few times, then whole info dash would turn off... take out key and try again, eventually it would just work as normal. Now it seems to be indefinite. Will not crank for the short while the info gauge is lit up, flashing the high temp warning LED. I can crank the engine upon shorting the solenoid posts. All the fuses in the rear and front boxes are good, disconnecting the temp sensor from its post on the cylinder head makes no change. Any ideas?
