seaduuude
I have a 92 GTX with a 587 motor. I had the carbs rebuilt a month ago because it ran a little rough. It starts and runs in the water just fine, full power and on plane. After it gets hot, it goes into a cycle of bog, rough idle, full speed for 5 seconds, bogs down, rough idle again, full speed..etc..etc. Like it is starving for fuel.
I let it set overnight and started it and it ran great....for 20 minutes...then the bog/run cycle starts again. I talked to a PWC mechanic and he is convinced it is a bottom end issue...crank seal..bearings..etc. Thoughts anyone? Could it be a fuel issue? Clog etc? Any help is appreciated.
