bell99man
For those of you replacing these for the first time, be careful of over tightening them. The housing and the case can strip or worse. I was installing my new one in the front into the oil separator housing. When it got tight I stopped and attempted to connect the wire to the plug. Well, it was too short because I stopped with the plug facing the right. My internal genius decided that a half turn more would line it up and I'd be done. Nope! A quarter turn later I felt it give and no longer resisted turning. I had broken out a chunk of the housing making that last half turn an expensive mistake. While you guys ride this week, I'll be waiting on a new housing. Since I'm down, I pulled the pump, found an o-ring off center, wear ring is shot and the pump is probably not in line with the motor. Might be ready by Saturday night, sigh.
