Oil Pump Bleed Screw Broke Off
Edwinh12
Well I went to bleed my oil lines on my 98 gtx limited and as I was tightening the screw back, it broke in half and half of it is inside the oil pump but it’s still leaking oil so I’m gonna extract it today and try to find me a replacement. Before I do so, is this some special screw or can I replace it with something I find at a hardware store? Did it have a small washer on it as well? IMG_0878.jpeg
Yep, came with washer, soft aluminum, ("crushable" by design?)
A few pics with metric/SAE measurements.
McMaster Carr has these but as you well may know, just cant buy one.
I.D. important, O.D?. Not so much so long as you keep it in the ball park.
Almost forgot, a s/s metric machine pan head (phillip's) will suffice but I'm sure there are other types would work. It's just phillip's give me a better feedback on torque applied.
View attachment 68925View attachment 68926View attachment 68927View attachment 68928
Think this would work? Thank you by the way! https://www.lowes.com/pd/Hillman-4mm-0-7-x-6mm-Phillips-Drive-Machine-Screws-12-Count/999994830
