sledman1
Putting back together a 4 tec engine and I am unclear as to how the one timing chain guide is attached. Just about to close up the crank housing and I wanted to make sure that I did not need to install the one timing chain guide before I do that. I have the one guide/tensioner installed (never remove it) but the one guide that is long (PART NUMBER: 420236501 420236500) and skinny is not installed at this point. Can I slip that in from the top later on and how is it attached? I can't see at this point in the process as to how this timing chain guide is held in place. Thanks so very much for any help. Just don't want to close up the crank housing and find out later that I should of installed this part and have to tear it all down again.
