Recently bought an '05 787 3d. I have the manual but cant find a home for a loose tube. When cleaning the engine compartment i found a tube that goes out the port side, toward the bow, that is disconnected from wherever it supposed to come from. There are three tubes breaches the hull at that spot. The left tube appears to be a gas tank breather tube. The right tube is about the same size and connects to the exhaust pipe elbow just above the 2 rave valves. The middle tube is pretty small, maybe 6mm, but i cant find a fitting for it. Where does this tube connect? Is it supposed to be attached to the bilge pump?
Thanks in advance for helping here.
