AircraftDoc
2006 RXT. 36hrs oped in salt water.
New spark plugs and SC oil and coolant change.
Fresh water test run and SC break in. Top speed 67.
Problem:
Squeal from aft at around 6000 cruse. Slow take off.
Ran from idle to full throttle and hit rem limiter 8050, it just spun.
Inspected impeller and found some dents on the blades.
I have read other posts. Correct me if I am wrong.
#1. Pull the pump housing. Straight out the impeller and replace wear ring.
#2. Question on greasing under the spinner cover? Could not find anything on lubing the spinner cover in shop manual. Is the bearing a sealed and different from the old 2 strokes. XPS grease?
I have read in other posts to lube this. I also have a 2004 RXP. Please advise.
Problem:
