Hey, newbee here. I’ve been searching the web and forum to get help as I don’t know much about these PWCs. I bought a used SeaDoo GTI 155 last year (65 hrs total). It’s had a few problems, first had to replace a knock sensor and this year I’m having IBR module malfunctions. It was an intermittent problem originally. I would get a loud “beep” an engine icon and a message saying “IBR Module Error”. When i found the maint code it was a C2102. The Ski would go into limp mode and limited my RPM and speed. The last failure It always was dumping the nose downward and I was unable to control the VTS. Sometimes I would turn it off and back on and it would work normally but eventually it kept coming back. Last outing it was stuck and I crawled back at 4 mph. I took it to a SeaDoo repair shop in my area. I called them today to get an update and they’re still assessing the problem. They said the tech believes it’s a bad IBR motor and said the parts are backordered until the end of Aug and they’re around $1,500 just for the IBR motor. They also said that if didn‘t care about not having reverse they could disable the mechanism and I could use the jet ski for the rest of the summer.
1. So does this make sense to the folks on here that are more experienced than I?
2. Can I have my IBR repaired Vs replaced?
3. Is there a way to confirm the finding and not just throw parts at the problem. I’ve worked in aviation maintenance for a long time and this is an expensive way to troubleshoot. I always told my aircraft mechanics they have to confirm the problem and not guess because aircraft parts are outrageously expensive.
Thanks in advance,
Thanks in advance,
