strake
Michael,
I read the entire thread end to end and I've had the concern for the past 2 years with our iS model GTX as to WHERE the water goes when the footwells fill up while our ski sits, COVERED on our lift? Obviously when the footwells fill up and the water spills out of the black base it goes into the lower hull.
Twice, I've gone back to the dealer with concern and they keep telling me it will go out the rear drains, even though they are screwed in. I keep telling them, yes I would agree when you are running the ski, but when it's just sitting there I don't see how any water can escape.
Just after reading about half of this thread, I went down to the dock and removed the cover and lifted the rear compartment. The fire ext well was totally dry, and then I removed that housing to look down past the battery into the bottom hull with a flashlight. I was greatfull to see it seemed dry, but again, I'm baffled as to where the rain water goes after it fills up the footwells and spills into the lower hull.
I would like to do as you have done and suggested by putting in a fully automatic bilge pump. I just can't figure out how to get into such tight quarters to install one. It is on the side with that fire ext and battery in that well, or the other side? I also pulled the seat and engine cover, and it is soooooooooo tight in there I couldn't fit an arm in if I tried.
thanks for everyone's suggestions.
