I haven’t had to winterize for the last 4 years but doing outside storage this year and need a reminder what hoses need to be pinched off before gravity feeding with antifreeze. Tia
I have exact same boat as you. I did the winterizing myself the past two years and I did not pinch off any lines. Just pump until you see antifreeze come out. Of course, make sure you start the engine first before pumping the anti-freeze in. Once you've started pumping, turn the pump off once you see anti-freeze coming out. Then shut your boat down.
One word to the wise, my exhaust temp beep came on during the process...probably because my pump was not strong enough (used one of those Menards AA battery powered pumps). I was able to complete the process and shut the engine off, but I will be using a stronger pump this year.
