I have a 2008 rxp supercharged (44hr on it) and I am having several problems, or one problem? Sometime in the summertime I noticed the pwc wouldn't always start on the first try but I would have to press the button several times before the starter would turn over and everything would be fine. Second last time I went out there was lack of power and it appeared as if the white key was in as, power was lacking and top speed was maybe around 60km/h. After 5 or so minutes the power returned and everything was fine but the top speed would max out at 103km/h while before all the problems began it was 113km/h. That same time upon starting the seadoo for the first time the rpms were fluctuating very sporadically some 200rmps from where they should be. Now last time I took it out to pay attention to the rpms I went out on the water same problems occurred but the pwc almost died on me on the lake and was loosing power which prompted me to turn back and once I turned the engine off I couldn't restart it again even when the starter tried to turn over. At home I inspected the impeller and seen some foreign material in the impeller which I removed and the pwc will start after few tries but it tries to die if I don't press on the throttle and the rpms are also sporadic. I will troubleshoot it maybe this weekend but if anyone has any suggestion please help me out. Thanks.
