Hello all, I just picked up 2 2008 rxps. The 215 has an issue where when you hold wot and it reaches near full speed something slips and power is lost and something inside is chirping and almost grinding. Almost like a clutch is slipping, but it usually only happens when holding wot and going almost full speed. Have to wait for it to slow down then apply throttle again to get going again, if i try to cut throttle when it happens and then try to throttle up too soon it just keeps slipping. Also i think the max rpm i saw was only 7250, but im not 100% sure, my rxp 255 does avout 8200 rpm.
is this the wear ring or is the impeller slipping on its shaft? Im not too familiar with the jet systems, i am familiar with how motors work...
also on my rxp 255, when i am going slow or just idling and i hit wot, it is pretty slow off the line, i get more 'pick up' when i ease into the throttle rather than do full burst.
im guessing that is from cavitation? Is the prop/impeller in need of replacement? How do you check if you have blockage from seaweed or twigs or anything in the system?
