Seadoo wake supercharger 215 issues
KILLSHOT
Hi guys so I finally after a lot of stuffing around going from shop to shop to shop have my seadoo wake 215 started ended up being a dead des post ring on top of having the ECU completely reset and re programed buy the guys down at sale seadoo can't thank them enough got it onto the water today got it up to 63mph not sure if that's good or not. and it's throwing a oil light and going into limp mode when cornering untill u release the throttle then it has a couple hiccups then goes again iv attached a pick of what the oil level is after holding it at 4k rpm for 30 seconds and pulling the key after warm up is that level to high also I'm having issues with the thick red wire. With blue tracer coming from the 30 amp charge fuse it keeps melting the 30 amp fuse and throwing a code p0562 any help will be appreciated TIA
63mph is pretty good for an older 215SC boat. Hard to see the dipstick but you definitely DON'T want to overfill these engines. Was the boat level when you checked the oil? As far as the p0562 code is concerned, have you had the battery tested?
