Searching for dependable ski to cruise around the lake and maybe tow an occasional tube. Limiting search to 4 stroke, naturally aspirated engines. I'm focusing on Sea Doo 2 or 3-seaters for stability, and because I am not a small person.
Found a 2008 GTi SE 155. 102 hours on the meter. Engine looks clean, and I tested compression 128, 120, 125 (cold engine with a Harbor Freight gauge). Hull looks good (couple of minor scuffs). Engine starts easily.
Two concerns:
1. Engine accelerates fine to about 30 mph (~5000 rpm) and holds. This problem appears intermittently, but often. I suspect a defect in the fuel system (filter, injector, pump...)
2. The ski has been parked on a trailer since winter with the trailer tipped backward. It appears that some of the oil spilled and ran into the bilge. No leaks were observed elsewhere.
The ski and trailer are being offered for about $2K less than NADA value.
I am pretty mechanically inclined. Have worked on cars and small engines, but no Sea Doo experience.
Questions:
Anything else that I should consider about the acceleration problem?
Any concerns with the ski being parked "nose up"?
Does this seem like a good deal? TGTBT?
