kastevenson
After my last lake trip, I went to drain the small amount of water in the hull of my 2012 GTI SE and no water would come out of either drain plug...Even after I backed the trailer down a steep section of my yard. I don't have the service manual and didnt bother to investigate other than sticking a poker into the ports to dislodge debris but it appears the drain plug ports are connected to rubber hoses and not open to the inside of the hull like I assumed..
Perhaps after the 6+ years of me owning this ski that I never knew how these drains functioned as I've always had to use an absorbent towel or shop vac to get the small amount of water in the bottom of the hull out.
This also opens up the question as to how much water is normal to be found in the hull after a day on the lake? For me, its around 1 quart or about an inch of water in the lower rear of the hull under the engine.
Thoughts?
Thoughts?
