Good Morning All,
I was wondering if any of you have add a similar issue or could shed some light.
My boat was running strange so i ended up ordering the Mercury Vessel View Mobile, it turned out be to a piece of wood stuck between the impeller and wear ring, thankfully no damage and it runs great now. No issues at all.
Well since i ordered the vessel view I installed it, and I'm getting a ton of sensor faults every time i use it, continuously. They are as follows;
Pitot Pressure - The input circuit for the sensor is below valid limit
Engine or Drive Trim Position - The input circuit for the sensor is below valid limit
Sea Water Temperature - the input circuit for the sensor is below valid limit
Level Sensor tank A - the input circuit for the sensor is below valid limit
Oil Level Senor - the input circuit for the sensor is below valid limit
I'm think it has to be a bad ground or something, the boat runs fine no issues at all or no beeping.
I did run the external oil tank oil to the point where the light and beeping came on, I immediately stopped and filled the reservoir, but the light and beeping continued, i took it easy straight back to the dock and pulled it out, and i came to figure out the engine mounted tank was a little low, it was about 1" from the top of the tank, i filled that and have had no oil issues since, so i think this sensor thing is unrelated.
Thanks everyone!
Thanks everyone!
