Recently replaced the oil pump assembly, exhaust manifold, head gasket, and starter gears. That required removal of the PTO. Everything is back together and the timing chain was carefully put back in the same position. Now the engine has a lot of trouble starting, drains the battery very quickly, and when it does start there is a crazy amount of smoke out of the exhaust. It will only stay running if the throttle is up a bit. When it drops back to idle, engine will stop. Must be burning a large amount of oil. Not sure what to look at next. Any suggestions?
