robrat20
Ok I bought a 2001 GTX RFI for 350 dollars with a trailer. The thing ran with 118hrs on it but only had 25psi on both cylinders. I did a water test to make sure it would float and run did about 12mph with 25psi, forward and reverse worked. I bought a rebuilt motor with a no fault warranty. I have a manual and took pictures when I removed it, other than a motor and new wear ring everything else seems to be in running order. I want some pointers on reinstall that will make this process easier for me. I’m new to two stroke jet skis but not two stroke motors. I’m waiting for the new motor to arrive should be in the next few weeks. Here’s what I’ve done any suggestions will help.
Rebuilt rave things and rave blades sent to get clearance
Fuel and oil tanks drained and filters changed, fuel injectors sent to be tested and cleaned.
Inside hull cleaned
Cleaned all parts and bought all new gaskets and o rings for reinstall.
Wear ring is in the mail
Thanks Rob
Inside hull cleaned
Thanks Rob
