Hey guys, new to the site and have found everything on here to be very informative and love it.
I owned a few superjets and thought it was time to get a sit down so I bought a non running 2000 XP. I know very little about the ski but that it has no spark.
I’ve been working on it for 3 months now with no luck. First time I put it all together and tired to get it to run I got a loud boom out the exhaust and blew a crack in the resonator. I assume from unburnt fuel. I checked the spark after that to find that it was intermittent. I went on vacation and when I came back there was no spark. Not sure what’s up so I charged the battery and it seemed to have the internment spark again. I thought it would be the stator or pulse could so I bench tested both and they seemed find. Did the start button 5 times to get the correct 1 beep so I was convinced it was the pulse coil. One other weird thing it was doing, it would show rpms once in a while. Seemed like it matched up with when spark would go.
So I ordered a used OEM stator and I installed it and now i can’t get the beeps from the mpem. Anymore. The 7.5amp fuse seems to keep blowing, but I think that’s the VTS, so possibly a different problem? I’m a little lost at this point. I’m used to very few electronics and it seems like this thing has me stumped.
As of right now when I put the key on I hear what I think is the fuel pump run for 2 second but there are not any beeps. If I hit the start button it turns over just fine but no spark. I have +13 volts at the 15 amp fuse on the mpem. I’m not sure what else I should check.
I’ve thought grounding issue but I’m unsure where to check the ground. Any help that could be offered would be greatly appreciated. Thank you guys!
