I have a 2000 GTX and the starter is grounded. How do you remove the starter????
Hi, I have a 98 Gtx Ltd and am trying to get the starter motor out,the engine is the 951, I'm sure I read somewhere that you need the engine out to remove it.
I have got the 2 allen bolts out but cannot get the starter out of the housing,
Any suggestions would be appreciated.
Thanks for that, I have removed the rear bracket bolt, there is a copper or brass bolt that a cable is connected to through the body the head seems to be turned off, do I need to get this out or is it just an electrial connection to the casing.
Many thanks for your help,
I see where you have the two allen head bolts out but you don't mention that you got the bracket nut off. The bracket on the back side of the starter is additional support. If you did not remove this, it's your hold up. The engine does not need to be removed to get the starter off. It would have to be removed if you needed to get at the starter drive assembly. You'd have to remove the magneto flywheel. The starter gear assembly sits behind it.
So, to double check, you have a total of "3" retainers holding the starter on.:cheers:
These starters only have 2 bolts on the rear bracket that secure it to the engine, not 3.
Chester
