2 easy questions
92rslt1
99 xpl 951
where are the grounds locations? The manual doesnt say.
My rave valve hoses lead to a solenoid.. from there one hose goes to the back and the other with the check valve is supposed to be attached to the crank case. Where on the crank does it attach? I have found it to be dangling under the case not attached.
1) Grounds. There are too many to list. Just look at the schematic, you you will see what they are hooked to, but not where.
2) There should be an extra nipple on the carb side of the engine. (There is one on each jug) One feeds the fuel pump as the "Pulse" hose... the other goes to your RAVE system.
2 ground locations of the 951 motor, front left on mag cover will have small wires attached and under carbs behind starter will have the main large ground wire location
The line with the check valve attaches under carbs next to the pulse line above the main ground location.
