chazdo2
I have the 951 GSX limited. I can not get the rpm,s to come up enough for the machine to hardly run. Just putts in the water. Both plugs are dark but not wet. New plugs same thing they do not appear to be fowling. Cleaned the carbs and carb filters and fuel filter.. Blew out all the fuel lines. Pop tested both carbs. They are both synched. Compression is 135 psi both cylinders. New pump and impeller. I am out of ideas
