pocket6722
First let me say thank you to all that have responded to my questions. The only problem I have left.... I am not getting power/pulse to the white wire going to the PTO coil. I marked the PTO flywheel to make sure when the trigger coil passes over the raised points on the mag/stator drum that I am picking up a signal. Every time the trigger passes over one of these points my meter readings change, I guess??? indicating that it is working. What other test can I perform?? or does this mean that it is possible the mpem is bad. I do hear two beeps when I initially connect the lanyard, then about 7 or 8 seconds later it gives me a single beep that last for two seconds. I have cleaned all the metal particles from the stator and everything checks out O.K. The resistance on the coil is 259ohms, which is in what the repair manual states. I just hate to spend $1500 dollars for a new motor and cannot resolve the spark issue.
