EdwinBland
I have a 1998 GTX LTD recently acquired.
History: It had a top end rebuild by previous owner. However, previous owner had wired the battery ground to the starter plus terminal…
I got it running after repairing the rear electrical box and replacing the rear harness with one pulled from a 99 GTX LTD donor. ( it has an unused wire since the 98 only has one coil control line). I also put a good AGM battery in it… borrowed from a running 99 GTX LTD.
Also tested with the other MPEM it came with… runs on either MPEM… with gas/oil manually injected into carb holes. All guages were working…
I put the carburetor back on today and fired it up… it ran for a few seconds and then lights out… the display went out.. it no longer shows any sign of life… I measured the battery at 14.9V on a HF voltmeter…seems too high…
I have two MPEMs… albeit one with a bad pin… I was previously able to run the motor on either of these…
I verified the ground wire lug to battery neg terminal is 0 ohms…
I’m thinking the voltage regulator is bad…
Needing a little guidance.
Ive read that some folks don’t recommend using AGM batteries on the older skis…
It seems like the MPEM is dead…
Any suggestions on how to test the MPEM are welcome.
