Tailgate4jc
First off thanks for all you help to come.
I have this GSX now for 3 years. I have changed the gray fuel lines to true black fuel lines. I have removed the small filters in the carbs and cleaned and rekitted the carbs. I have an inline filter along with the factory water separator/screen. Ok so what is my problem. When I put this thing in the water man it runs great for about 20-25 mins then looses mid throttle. It idles fine and a little throttle is fine. Up till about 3000 rpms. Then more throttle makes it really bog down. If you hold it wide open sometimes it will take off. Like wide open runs. Seems to run fine at fill throttle. It likes to go fast.
Ok on a side note Im not sure if the lines to the tank are plumbed correctly. When I fill it up with fuel it will start leaking fuel out the side port. I thought since it did that the vents might not be correct. When it starts this bogging down I tried opening the cap to let air to no help. I have the manuals but its not real clear on the plumbing of the fuel lines.
Any help on either of these problem and I hope they are connected is great appreciated. I love all the information on here and so much of it has helped. I am so glad there are so many comments of the gray fuel lines. My were nasty and the screens where plugged.
