KNiswander
Anyone who has had issues with Engines surging from high RPM back to low RPM please read this. I was told to clean the carburators and the carb filters inside the carb and that should correct it. If that does not correct your problem inspect your on off valves. I pulled mine out to find they were deteriorating inside and not allowing full fuel flow which was causing the surging. It is a pretty easy and inexpensive fix I would definetly start here it fixed mine. Good Luck.
