Hi all
I recently acquired a pair of 1997 GTX. I was told they don’t run because of fuel problems. The registrations show they were last on the water in 2021.
I’m not sure if the previous owner stored them for 4 years and then they wouldn’t run, or if they were parked because they wouldn’t run.
From what I’ve read online, the fuel hoses break down on these and let a bunk of gunk into the fuel system. The fix seems to be to replace the lines and clean the fuel filters on the carbs. I checked mine and they do have the gray fuel lines.
I have no money into these jet skis. If I wanted to just see if they’re worth putting some time into, is the best option to pour a little fuel mix into each carb and see if it will run? Then if they run I can take the time to replace fuel lines, fuel filters, and any other maintenance that might need to be done
Thanks in advance
Thanks in advance
