henryb
I have a 2004 Seadoo Speedster 200 - 310HP, and I have been struggling to get the Gas Gauge to work properly, early in the season, it would just sit at Empty. So I tried moving it from one Fuel Pump connection to the other Fuel Pump... that seemed to work a bit better, in that it went to 3/4 full (which I thought was about the right amount of fuel in the tank). However, it did not go down as the fuel was used up.
Further testing involved removing one of the Fuel Pumps and checking the effect of moving the float manually... basically moving the float to anything above 1/4 full would have the gauge display Full, then allowing the float to drop to the bottom of its range, the gauge would display 3/4 Full. So, we are fairly confident that the issue is with the gauge itself.
I looked around for an aftermarket gauge, but there does not appear to be one that supports an easy plug and play with that 6-pin connector on the back? I was told to try and find someone that might have a used OEM gauge that still works?
Anyone have an extra Gas Gauge that your willing to part with?
Let me know,
Thanks
Let me know,
Thanks
