I have a 1997 speedster with 720s. I am having issues with the Port side engine tuning and I can't find my particular issues already discussed. Compression at 130-132. Single Mikuni carb rebuilt using genuine Mikuni parts. cleaner flows through all holes in the carb well. I can not find the low and high needle settings for the speedster. The pilot jet is 67.5. The main jet is 182.5. The initial setting I used is Low: 1 High: 1.5. Idles set at 1500 in water. Pop-off 36 psi.
Here are the issues I need help with:
- The engine dies when throttled back to idle. Must add throttle to restart. will stay running at 1900 RPM.
- The engine will smoothly go up to 4000 RPMs. Approx. 1/2 throttle. No change in RPMs through 2/3 throttle. Then a jump to 6000 RPMs. I can then back down the RPMs to about 4500 RPMs without feeling a surging in the motor. I am assuming this surging I am feeling at 4000 - 4500 RPMs is the pop-off turning on and off.
