1997 daytona 1000 tigershark
swan
still need help,,, 120 psi in all 3 cylinders runs on trailer but i see fuel comeing out of exaust, wont run in the water ??????? there is spark in all cylinders.. HELP
Take the carbs apart, and verify everything in them.
While they are off... make sure your reeds are good.
If you have spark, compression and fuel... it will run. With that said... I dont' know what a Tigershark static compression should be. SO... if it's supposed to be high, like a Rotax engine... then 120 is WAY low... and that's why it wont run in the water.
