ski-d00
a bad VTS will not cause it not to start, just unplug it. that is just a relay in the front elec box, the starter relay or starter solenoid(same thing) is in the rear black box. you need to trace the start button back to the MPEM to make sure the switch signal is getting to the MPEM, then trace the output signal from the MPEM to the starter solenoid. it is a simple circuit, try unplugging the plug from mag cover to see if that does anything, keep checking the fuses in the MPEM after testing. make sure the power wire red/purple to the MPEM is good and check for corrosion on the fuse in the rear elec box. use the wiring diagram Lou supplied above.
