1995 XP800 Restoration(Finally)
Any of you guys use the ultrasonic baths? If so what cleaners are you using in yours?
95 XP800!!!
Keep the 2 strokes alive!
I've used a purple power water mix 50/50. Sometimes it will darken the metal parts though. These days I just use Purple Power with a brush and rinse with water till squeaky clean.
Yes [MENTION=68602]Toolanddiemaker[/MENTION] has one he did mine i believe he used simple green works great
Sent from my SM-G920V using Tapatalk
Lol, you must be running huge carbs if you thought they were big.
No that's a good thing bc you guys said Dremel and there's no way the ones I was looking at would fit a Dremel
When do you want to align the engine? Side note I have some things that I want to blast.
This weekend? I have a stand up funeral to go to next weekend.
That should be fine, let me make sure the wife does not have anything planned for us.
Are you closer to Sinclair and the twin bridges area or Oconee and old Phoenix Rd?
95 XP800!!!
The last few parts I need should be arriving today. The hood decals and reggie numbers from Mike should be showing up Saturday. I'm hoping to make a lot of progress this weekend.
95 XP800!!!
Hopefully I'll get all the info finished up for you 96 clone today.
95 XP800!!!
That was the first time I even tested out the electronics. VTS even works perfectly
95 XP800!!!
I still need to fill it with oil, finish the carbs up and get them mounted. Then I'll fire it up
95 XP800!!!
