arizonabuild
Hello, thanks for the add. Been searching for answers for a while and decided to finally sign up. Look forward to being part of the community.
Currently have 3 Yamaha waverunners and just picked up a 1991Seadoo SP with the yellow 587(sounds like you guys probably get a lot of these first posts!). It has been sitting since 2007. Removed the mikuni carb and re built it with an oem kit. Replaced all the gas lines and filter. The carb now draws fuel but goes into full throttle "runaway" mode when started. Took a working carb off one of the Yamaha 500's(same carb), used a brand new gasket, and it does the same thing so I don't believe it is a carb issue. Sprayed with carb cleaner all around the engine and could not find a leak. I'm guessing it is the crankseals but before i pull the engine was wondering if there is anything else I should look at or test first? Could leaking oil hoses be causing this? Compression appears a little low at 120 in both cylinders, maybe something in that area?
Just looking to get it running and have some fun. I'm fine with some expense and enjoy this type of work, just know very little about seadoo rotax engines.
Thanks! AZBuild.
Thanks! AZBuild.
