1996 Seadoo sp starts and dies
Harrison22
Ive been working on my 1996 seadoo sp trying to get it ready for the summer and I rebuilt the top end(has 145 psi on both cylinders) and changed all fuel lines and rebuilt my carb which I pressure tested and it meets specs, I’ve also got new gas in it aswell and it starts up but dies shortly after it’s not consistent either it will run for 5 seconds then die then the next time I try it dies in 10 seconds which is the longest it will idle what else could it be? I feel like I’m out of options🤷‍♂️
it sound like you got a carb issue. Make sure you got all the lines hooked up right and what brand carb kit did you use
