07 seadoo wake 215hp need help
seadoo_103
So I took off the VENT VALVE to get the Super charger off and when I went to put it back on the washer that goes between it and the timing chain gear Fail down into the block and I can’t find it I have tried using a magnetic screwdriver and a piece of Metal wire no luck any help would be great At this point I’m thinking about just leaving it in the block And ordering a new washer part number 420627494
You will have to remove the MAG housing to retrieve it. Do not leave it in there. It will destroy your engine.
Chester
I would remove the engine to do it
You are more than half way there to get the PTO cover off
You’ll need a new PTO gasket too and clean oil screen whilst it’s open
