chicknwing
01 GTX DI Updated
A little background on this ski first,
I acquired this ski from the original owner who bought it new in 01. He told me that he had been having some issues with the ski being stuck in limp mode and had made several trips to the mechanic with no relief from the problem. He finally threw in the towel and parked the machine in 2008 (last state registration sticker). He offered me the ski for $500 and I politely declined. I made a counter offer for $100 since I had not seen it. We ended up agreeing on $200 sight unseen. (the ski was 5 hours away) I was told the ski might have 30 hours on it. But a photo before i went to get it showed writing on the inside of the engine compartment showing a date from 2006 compression 105 on both cylinders and 46.2 hours.
I spoke with one of my friends who is a master Yamaha mechanic and he told me to go for it. (worst case part it out). I picked the ski and trailer up last weekend and brought it the 300 miles back home and now the process begins.
First thing i noticed is the starter relay is disconnected and lying in the rear storage box. I broke out the shop manual and did a bench test on it with the multi-meter. Checking the resistance it appears the solenoid is an open circuit. I charged the battery and re-installed the solenoid in the ski and installed the key. Got the two beeps (good so far) hit the start stop button and nothing. I can hear the fuel pump running but that is all. Got the multi-meter out and checked the dc voltage to the posts of the solenoid. Battery side is correct showing 11.89 vdc. starter side showed nothing. Pressed the start stop button and checked. No voltage. On the multi-function gauge the ski shows 89.2 hours and the red light is flashing and "MAINT" on the screen.
I found a relay on ebay for around $25, I believe this is the next logical step so the machine can turn over and I can do a compression check. (I could jump the posts on the relay to turn it over) If you guys have any advice on next steps please feel free to post below.
