'01 GS grey goo coming from exhaust not staying running
So heres my issue
i just bought 2 seadoos (01 rx and an 01 gs)
They have been stored for 2 years and not been kicked over since they were winterized in 08.
I replaced the battieries in both of them and i drained the gas out of the RX first and put fresh gas in it with a can of SEAFOAM. After a little persistence and vocal encouragement it kicked over and runs like a top...happy guy.
The GS on the other hand, i got a little ambitious and attempted to start it with the old gas in it. after 2 failed attempts i followed the same procedure that i did on the RX
No bueno.
It kicks over and will run only if i pour carb cleaner or gas right into the carb.
when it does run it has EXCESSIVE smoke, and when i say excessive my rottwieller goes running becuase she thinks its some sort of monster.
It will run while the gas ive poured in the carb is still present, and then will bog out after about 10 seconds even under revs.
Now the kicker..... after repeating the gas in the carb trick for about a total of 1 minute running time GREY SLUDGE starting coming from the exhaust pipe.... semi thick equivilent to old motor oil from a chevy pickup mixed with water.
Any ideas on what this could be?
I cleaned the fuel filter under the console (not dirty) and noticed i still have grey tempo lines... hoping i wont have to replace these right now... i just wanna see it run on its own...
thanks for any ideas or feedback
So heres my issue
No bueno.
