lamajama
I know this will sound like a stupid question - but I have gone through 19 pages of search results and gave up.
Lots of comments on 2 strokes and mixing but none I could see on the 4 stroke...
My question is this - I just moved up to a 4 stroke and the PO was using QS 10W30 oil for some reason.... and I'm doing an oil change and changing it to the XPS Synthetic Blend.....I won't be able to get the full amount of the old oil out
as everything I've read says just leave the balance of the oil the pump can not get out on the first attempt (probably leaving about half a quart). I know you can turn the engine over a bit and get some more out but as I said I would rather
not run the engine without the lubrication...
Should I make an effort to get as much of the remainder out as possible or will it be ok to leave this old amount? I
would imagine the ratio would end up as 3 1/2 quarts new to the half-quart...
