copperhead
Hi every one, I am new to this site and have just been a seadoo owner for two months. I have been reading the many posts on this site trying to educate myself in the world of sea doo jet boats. It becomes apparent the more one reads the threads on this site how many expert sea doo jet boaters there are here with a wealth of knowledge they are willing to share. I bought my boat from a dealer in Indiana and had it shipped to Canada. The dealer had performed a mechanical check on the boat. The compressions were 135 psi on five cylinders and 140 psi on the sixth cylinder. They did a tank test and ran the boat under load and said every thing was working fine. When I got the boat I changed the water/fuel seperator filter, the inline filter, the six spark plugs (NGK) gapped 0.04, the hydro surge weed grate (installed six tine alliminum fixed), charged the battery fully, filled the gas tank with new fuel (tank was nearly empty), added one can of sea foam , the appropriate amount of fuel stabilizer. Have had the boat in the water four times. The boat starts and idles smoothly, no missing, there is no hesitation in acceleration and planes nicely, but the problem is that the boat will only rev to 5100 rpms and go 42 mph. I know from reading all the info on this and other sites that this boat should max. rev 5750 to 6200 rpm and should go 49 to 52 mph. I have checked all the cdm's and plug wires for connection. There are only two things that stick out in my mind, after three months of faithful thread reading: the throttle shift lever at WTO does not go all the way to the front of the console as the FNR lever does, but is away from the end by approx. 1 and 3/4 inchs. Could the max. throttle linkage be set incorrectly? The max throttle stop on the engine still has orange sealant on the thread, so I don't think it has ever been moved. The other is the exhaust hoses feel soft and I have read on this site about exhaust hose interior de-lamination and exhaust blockage. I am terribly sorry for the long thread, however I did want to give you the background for what I have already done to the boat. Any help would be greatly appreciated. Looking forward to hearing from you folks.
best regards
Terry
best regards
Terry
