P philbilly91 New Member Aug 8, 2023 #1 Just wondering if anyone knows the dimensions or the wrist needle bearing on a 787. The ones I got are 22mm wide and there seems like there is no way that both of the thrust washers will fit.
mikidymac Moderator Staff member Moderator Aug 9, 2023 #2 If they are aftermarket bearings you do not use the thrust washers. The thrust washers are only for the OEM cageless bearings.
P philbilly91 New Member Aug 9, 2023 #3 mikidymac said: If they are aftermarket bearings you do not use the thrust washers. The thrust washers are only for the OEM cageless bearings. Click to expand... Thank you
