XARiUS
So I am rebuilding a 717 and got some new crank seals, I have been fighting with the rear PTO since the start. I have an old drive shaft that I am sticking inside the spindles and cranking on to try and bust it loose, I heated the shit out of it, and now, I tweaked the Woodruff key on the magneto side while cranking on it. Can i get another key at most local hardware stores, or is this something I need to get specially?
Also, Does anyone know any tricks to get this damn PTO off?!
Thanks in advance,
Oh, also, my rotory valve shaft was stripped, could this be caused from lack of oil to motor? I think my oil injector may be bad but am not sure if I can test it, I tried to blow lightly into the oil nipple and couldnt blow through, no matter what position the lever was in(which wont return to its default position, sticks open)
Thanks in advance,
