After installing the needle and seat of it leak around it anyway to fix that??
Ok great help thanks, dumb question why is the pop off pressure so important?
In your first picture you are using the wrong black rubber diaphragm and the seadoo’s don’t use the yellow paper gasket.
Use my carb rebuild thread up top in the Sticky section it will take you step by step. Also you might have already damaged the lever arm by bending it back and forth.
Sometimes I’ll get it to pump up to like 40 I’ll adjust the arm and it won’t pump past 25. My pump hand getting tired lol thanks
Did you get new arms/pins with the kits? You shouldn't need to adjust the arms if they're new with the pin and the new 80 gram springs. I did 2 sets of 787 carbs for my ski builds, each time it was dead on 34-35 psi on the pop off, little wd40 and slowly applying air..
As far as assembly just go by the sheet with the kits for the BN40, a couple pieces will be odd fitting, those are for the BN38 carbs.
Ok thanks got it to pop twice at 28 psi
Yes, that's great if they both popoff at the same pressure. Don't neglect the tiny holes talked about in the Carb Rebuild Thread. Getting those to flow cleaner properly is a must. Pulling a single wire from a wire brush works great for those.
28 psi is a little on the low end but still within spec, 35 range is ideal.
Are you 100% sure you are using 1.5 needle and seats and Black 80 gram springs?
