My neighbor knows I am super handy with 2 strokes - and asked me to look at his 2002/2004 gtI seaDoos, The symptoms he said was runs fine for 10-15 mins then surges or does not rev out - he of course is not technical at all I tried to ascertain if it was fuel surging or like overheating and hitting safe mode or rev limiter i.e maybe over heating.
Going down the over heating path - I started to look at all cooling lines as to me sounded like it might be overheating then going into a safe mode (I am not sure if they can go into an over heat mode can they? (I know my 1990 yamaha waverunner could go into a over heat mode and limit rpms) - disconnected them ALL (exhaust, head, pump intake, exit etc) and blew air through them freely, pulled head off and really nice and clean I was hoping or expecting to see weeds or sand in there no such luck. Can the venturi bilge pumps get clogged up or cause any problems in cooling system lines? (Vacuum or blockage????)
I checked temp sensor - it has continuity but an open no resistance reading when at ambient temperature - I did try to warm sensor with a heat gun I heard it click.
I have scoured the internet found one guy saying rubber grommets (top hat shaped seals/ rubber bushings) (at the back of the machine where the pump connect to the haul) in the pump housing can collapse when warm restricting water flow - any way to test or verify this? (other than pulling out pump/jet and seeing how soft they maybe?)
can a fuel line start to collapse after they warm up? Or
What would electrical symptoms be on these machine - bad cdi bad rectifier,
Can any one give me any ideas and what to look for on how to trouble shoot these machines ( neighbor claims carbs were rebuilt by a shop and that did not fix the problem)
