What parts are compatible?? help please DR HONDA??
Chillpike79
I have a 1999 challenger (twin 787's) and both of the head pipes are leaking pretty good, the guy i bought it from tried to epoxy or jb weld it, well anyways both of them are leaking in at least 2 of the notorious spots, i was wondering what other skis (xp,gtx etc...) or if any of the 787 head pipes will fit the challenger application. im taking it to a mechanic to take them off and weld as long as they are not too far gone, but if it would be better to replace them, what all will fit? Thanks Im sure someone knows this!
Well, I ain't Dr. Honda, but if you don't mind, I'll set you up.
Your model 787cc in your boat uses part #274000161, which runs about $846 bucks. I've seen this pipe for sale in the $600 range, but you'd really have to look for it.
The models and years you can cross with are: 1999 Challenger 1800, 1996-97 XP, 1997-98-99 SPX, 1998-99 Speedster, 1996 Challenger, 1996-97 GXS and the 1996,97 GTX.
Hard to believe the JB didn't hold. Makes me wonder if they used the right stuff. I have a head pipe on my 97 Challenger that I used the high strength JB weld on. That was about 4 years ago and it's still doing good. I admit, the best fix is to have it welded, but aluminum welding doesn't come cheap. Also, welding a "cast" aluminum is brittle and will sometimes crack under heavy vibration.
The key to using the JB weld is preperation. I used a Dremel tool and cleaned out all the area to be bonded. Then, I used a piece of aluminum screen to cover the area. After I covered it, I put a thin application on, let it dry. Then, I lightly sanded and put a second application on.
These water leaks of the head pipe are common. The water used for cooling circulates around between the inner and outer part of the pipe, pre-heating the water before it enters the cylinders. The chemistry involved in this is, when the water heats up, minerals leach out and adhere to the metal. Over a period of time, it begins to insulate the inside walls. The sodium chloride (salt) is what does most of the damage.
Good luck, hope you can find or fix yours. Remember, the water pressure on this area of the pipe, really isn't that great. So, if you want to try the JB again, make sure you do a really jam up job on cleaning and exposing fresh aluminum, so you can get a good bond. I know, before I paid that kind of money, I'd do the JB weld fix again. To get 4 years out of my fix, I'm o.k. with doing it. But, I also own a MIG machine with aluminum and carbon steel wire.
Why don't you have it fixed, instead of using jb weld....Take it to a local weld shop and have them fix it.
Thanks for the quick reply! I really need to look at it closer I dont think he used JB on it,looks more like some kind of epoxy, i thought about just pullin them, and doing like ya said.... i found some on ebay for $75-150 (used of course) that look in good shape... though decision. got a guy that has a welder that can do the job, just dont know what he will charge...either way i need to make somehting happen, no fun sitting on the trailer.... Thanks again for the cross references!
Yep... what they said.
If someone brought me the pipes, off the boat... I would probably charge $35 each to weld them up... depending on if I have to clean them or not. (and if they brought beer)
If I had to take them off first... it would also be shop labor to remove, and re-install them... plus any new gaskets.
What do you think would be a fair price range for a shop to repair 2 plugs on each one, both bottom plugs are bad on each pipe, labor to remove/install and gaskets, welding, etc.... Just wondering if they try to screw me over or not. Seems there is only 1 place on MS coast that will work on seadoos, it's crazy
Ummmmmmm.....
probably about $150 to $200 if I was doing everything, and depending on how dirty things are. You would be amazed how that can vary. People bring me skis that are clean enough to eat off of... and some are so greasy that I have to spend an hour cleaning before I will start to work on it. (that adds $65 to the bill alone)
ok, thanks! the guy told me over the phone about 125 per side, or 250, without seeing it of course, so thats not too bad. I definately know what ya mean, when i bought it the guy before me knocked the oil hose loose when he was puttin the battery in and it was nasty, used the purple cleaner suggested by someone on here and it cleaned it up pretty good. Thanks a lot for your help!
well, got them welded up a few weeks ago, and everything good so far, glad i got them welded vs jb weld. when they took them off i saw how bad the under side ones were, completely gone.
