mkeough11
Ok, now what? Boat was starting just fine. Repaired jet pump, carbon ring and it started right up when I went to check everything. I then changed my bilge pump. I was down in the engine compartment, but was very careful. I then went to the bilge switch and when I turned it on, my electric fuel pump cycled and pressurized. Turned the switch off and back on and it pressurized again. It did it a third time. It was just like something was shorting out, or taking voltage and causing the DESS switch to recycle. It will now not give any beeps when the cap is placed on the switch. It is just like it has no power. Nothing happens. I checked all the fuses and they are all good. Even checked the one by the solenoid. Good also. Everything else works fine. All the switches, even the bilge switch works. Just not the DESS switch. Now this has happened form time to time, but not to this extent. Sometimes the battery was low and other times, it would just start working. The battery is charged and the motor turns over fine if you jump the solenoid switch, but of course will not start. Now, if I press the start button 5 times I will get 1 beep. It is like it is on a delay. It will beep 1 time each time I press it. But if I leave it alone for maybe a minute, then I have to press it 5 times to get it to beep again. And this with the DESS switch cap either on or off. How do I check the DESS switch to see if it is getting power? I have checked the connections and wiggled everything, but still no luck. I have a voltage meter and can check things, but have no idea where to start. Any thoughts about what I can check?
